ArcGIS Explorer Layer Packages - Not showing lines
6338
10
02-18-2013 05:17 AM
JamesParadis
I am new to setting up items for my field guys to use on ArcGIS Explorer.
I have a map with lines and points with labeling.  I have it in ArcGIS 10 and ArcGIS Explorer on my machine and it works fine.  Labeling is correct and all lines are there.
However, when putting everything into layer packages so the labeling works correctly in ArcGIS Explorer, whether building the package out of ArcGis 10 or the most recent ArcGIS Explorer build, it will not show the lines after sending it to my field guys.
All of the labels show up, however, you cannot see any of the lines.  The contents window shows they are there, they are showing the right symbols, the attribute table is correct, however, they just are not physically on the map.
I have created each set of lines into a layer with all of the information formatted correctly.  Then I take all the layers together and export as Layer Package out of ArcGIS Explorer, just as the instructions online state.
Any help would be greatly appreciated.
DavidLarsen
Joseph,
Thanks for the input unfortunately that did not work. However I did find a solution for anyone interested in using .lyr's outside of a network. AGX will load each separate layer file as long as that data is stored externally and the layer file is created with the Internet/network connection off. Hope this helps somebody else.
