Arcgis explorer images updates and projection question
2321
08-15-2010 11:26 PM
AchilleasDrosos
Does anyone know when in Halkidiki (Greece) would update its images...?
And another one when i project greek grid with transformation GGRS_1987 TO WGS_1984 i have no problem at 2D..
When i do the same in 3D the same transformation does not work please help
MichaelBranscomb
Esri Frequent Contributor
Regarding you first question - please can you clarify the question? Do you mean when will the Basemap imagery (ESRI World? Bing?) for the Halkidiki area be updated?
Regarding your second question - are you able to provide a sample of data in Greek Grid?#
Regards
Mike
AchilleasDrosos
Regards
Mike
Mike i mean bing or esri world i don t care i have a big project in Halkidiki and i want to use Arcgis Explorer...
For the second answer i can provide sample data but the attachment size is very limited can you provide me an email...?
Thanks for your reply...
MichaelBranscomb
Achilleas,
RE: Basemap updates:
Bing:- You can get the latest info on the Bing update programme here: http://www.bing.com/community/blogs/maps/archive/tags/Content+Updates/default.aspx.
ESRI World Imagery:- I am not aware of any published info on anticipated updates. More info on this service can be found here at ArcGIS.com (http://www.arcgis.com/home/item.html?id=10df2279f9684e4a9f6a7f08febac2a9) and in the ArcGIS.com Help (http://www.arcgis.com/help/content/esri/contributors_wi.htm).
N.B. You could also consider the ESRI World Topographic Map which is updated via the Community Basemaps Programme: http://www.esri.com/software/arcgis/arcgisonline/community-maps.html and http://www.arcgis.com/help/content/esri/contributors_wtm.htm
RE: Sample Data
If you have a small sample of the data you can send it to mbranscomb@esri.com
Regards
Mike
MichaelBranscomb
Achilleas,
I have just tested your sample data in ArcGIS Explorer 1500 (due out very soon) and it appears to display in the correct position (as far as I can tell).
Here are the steps I took:
1. Open ArcGIS Explorer
2. Set the Basemap to Bing Aerial imagery
3. Click the Explorer button/pearl in top left corner
4. Choose Map Properties
5. Select 2D Coordinate system tab
6. Pick �??Greek_Grid�?� from the drop down (via <More...> option)
7. In the Geographic Transformations box choose GGRS_1987_To_WGS_1984
8. Click OK
9. Click Add Content > Raster Data...
10. Browse for �??n.gonia_sdian63_58apo1.tif�?�
11. Click Open
12. This looks OK to me?
Regards
Mike
