ArcGIS Explorer and Panasonic Toughbook (CF-19) crashes on startup
2552
10-27-2010 09:23 AM
GordonAllen
We have Panasonic Toughbooks Tablets model CF-19 running on Windows XP Professional x86 SP3.  The latest .net and video drivers have been installed.  ArcGIS is installed on one of the toughbooks and it runs fine.
AGX Explorer crashes every time when the application loads and gets to the main screen it immediately crashes. (always at the same point).  This happens with the out of the box configuration.  We have tried version 1200 and 1500 with the same result.  We have tried both the current user and non current user versions with the same result.  We have tried with and without addons and same result.
Has anyone had similar issues with AGX and Panasonic Touchbooks?   Is it related to the special touchscreen drivers?  As mentioned, we have tested ArcMap 9.3 on one of the Toughbooks and it runs just fine.
JamesStewart
If it helps, I'm trying to deploy on the CF-30 and ArcGIS Explorer was crashing at startup.  I updated the video card driver and am good now.  So... my point is, it wasn't an issue with the touch screen... at least with the CF-30.
