Widget Controller cannot be customize?
1845
12-05-2024 08:46 AM
Muhammad_AzhaziqBin_Mohd_Azlan
I did try to export out the widget controller and try to customize it and hit with error.
Anyone have similar experienced?
ShaneONeill_144
Is this the first time you've had this issue? Have you been able to do this successfully in the past?
1st time hitting the issue
Allen_Zhang
Hi, you could try removing the LayoutItemToolbar. The component will render a context menu for some widgets(image, text, button) only in builder. Removint it won't affect other functionalities.
Make sense of the workaround. Thanks
