Updating existing feature via the survey widget in Experience Builder and get message stating editing not possible, but edit reflects in table
132
Friday
Bec
Hi!
I am using the survey widget in Experience Builder and have set it up to edit an existing feature.  When I select the feature from my table, all of my fields populate as they should.  The only field in the survey that is editable is the, Update Number of Devices field.  After making the update to this field and submitting the survey, I get the following message:  Editing is not possible because of the globalId parameter was not provided.  The table does have a globalId field.  And when I look at the table after the edit survey is submitted, the change is reflected in the table.  The survey itself is set to add and update records. And I'm using Survey123 Connect version 3.21.  I have added images below.  Can anyone tell me why I am getting this message still if it seems to be working otherwise?
Bec
Edit Survey showing the change to the device count before the survey is submitted.Edit Survey showing the change to the device count before the survey is submitted.Table showing current selected feature CountofDevices field before the survey is submitted.Table showing current selected feature CountofDevices field before the survey is submitted.Survey message after Edit Survey submitted.Survey message after Edit Survey submitted.Table showing the new value in the CountofDevices field.Table showing the new value in the CountofDevices field.Table GlobalID fieldTable GlobalID field
