Unable to pan/zoom above the attribute table
479
02-14-2025 06:12 AM
RachelS
I'm trying to replicate my attribute table from web app builder.
I have it across the bottom third of my webmap inside a side sidebar that goes up two thirds of the page so the user can expand the table upwards, just like WAB.
However the problem is the user can't pan/zoom inside the area of the sidebar when the attribute table isn't expanded upwards, which  is not great at all.
Has anyone any suggestions around this?
Thanks
Rachel
ShengdiZhang
Hi @RachelS ,
I think you are placing the sidebar over the map widget, which will block the map interaction whether the sidebar is expanded or not.
You can place the map widget in the sidebar - first panel:
You can refer to the Foldable Template, which has a similar layout.
Regards,
Shengdi
ShengdiZhang
Hi @RachelS ,
Regards,
Shengdi
RachelS
Hi @ShengdiZhang
Perfect, I got it working, many thanks for your help.
Rachel
