Table widget is not displaying coded values
1165
05-13-2022 10:17 AM
JoshDunsFCX
I have created a layer view from a hosted table in portal. The table has multiple fields with integers with coded values set up on them. When I create the view, the coded values are displaying in my new view within the Data tab in portal and in the attribute table in my web map where I'm viewing the layer view. However, I've created an Experience Builder app using Developer Edition and I have a table widget linked to my view, but it only displays the integer values and now when I view the data table in portal, my coded values are not showing there either. Is there any way to show the coded values in a EB table widget?
TianWen
Is it possible to post the data field structure or sample data here so I can investigate it? Thank you!
JoshDunsFCX
Thanks, Tian. For example, I have a hosted table with a text field called CoordinatorID, which is a coded string tied a value list with the coordinator's name. I've created a view layer from the table. The view layer is showing my value list, however, when I drop the table widget into my Experience Builder app, it is showing the codes, not the Coordinator's name in the table. If I wire my table widget to the hosted table directly, it shows the Coordinator's name as I would anticipate.
Hope that helps demonstrate the bug with view layers and the table widget.
