Survey Widget (send data to this survey)
5750
10
04-06-2020 11:17 AM
ZacharyVavra
I'm having an issue with the Survey Widget's "send data to this survey" functionality.
I'm attempting to create an app where the user selects an item in the List Widget and both the Map Widget and Survey Widget respond to the selection. The Map Widget is responding correctly (zooming to and selecting the feature), but the Survey Widget does not automatically populate the survey's fields with the selected feature's attribute fields. The survey only populates after the user clicks on the feature in the map.
The List Widget actions I have set up are "Zoom to" on the map and "Select Data Records" on the Framework.
Is there a way for survey fields to automatically populate a feature's attributes when selecting the affiliated item in the List Widget? I don't want the user to have to actually select the feature in the map to populate the survey fields.
The attached image is a screenshot of the "Balsam Volunteer Fire Dept" selected in the list, and displayed in the Map, but the survey field "Fire Station" did not update.
Thank you!
ahargreaves_FW
FIVE years later, still nothing...
