Survey widget - send data to survey fails for 1 connection
904
07-15-2025 07:35 AM
nworbi
Hi
Any ideas why 1 connection does not send data to survey in the Survey widget in Experience Builder?
The survey was created using Survey123 Connect. All other connections work correctly apart from Detection Type.
JuanTomásMartinez17
Hi! Could you please provide more details to help troubleshoot the issue?
  • Question type in the Survey123 form (e.g., select_one, text, integer, etc.)
  • Field type in the source feature layer (e.g., string, integer, domain, etc.)
  • How is the question configured in the XLSForm? (including the name and any bind::esri:fieldType, bind::type, default values, calculations, constraints, etc)
Also, a single check that could be the solution:
- Since it's a select_one question, does it use the exact same list of choices or domain values as the source layer?
Let me know so we can keep trying!
nworbi
Hi @JuanTomásMartinez17
  • Question type is select_one esriFieldTypeSmallInteger
  • Integer domain does match the feature layers
  • In the XLSForm, everything is blank apart from the field type
nworbi
As all my data currently has the '0/New' value, I didn't realise that other values show in the survey as expected. For some reason, it is only '0/New' that results in a blank
JuanTomásMartinez17
This explains the issue completely.
Since 0 is treated as a false value in JavaScript, it causes a compatibility issue when passing data between widgets.
A good workaround is to start the codes from 1 instead, or to use string values instead of numbers.
Hope this solves the problem!
