Send map point coordinates to Survey Widget from Map Widget
680
07-24-2023 11:48 AM
Labels (2)
RossmanThomas
Wondering if there is a way to send the point coordinates to the Survey Widget when the user clicks on the map in Experience Builder.  It works well if the user clicks on a map feature (using *Shape(point)), but if the user clicks on a blank area of the map, no coordinates are sent to the survey and the survey point feature ends up at 0,0.
Thank you.
