Rearrange Series in Bar Chart
1032
02-14-2024 09:28 AM
nrezvanpour_arc
I am trying to use very simple functionality of reordering my fields/series and I am trapped as neither ExB nor GIS Pro does not support that! I have created two stacked bar charts in ExB, one with Base values, one with changeable values for my data but I need the fields order to follow each other in both charts (I am using two separate layers in one web map). I also tried multiple time to rearrange my fields in Pro or AGO and then try it in ExB, none of them worked and it is so frustrating.
Any idea?
Wei_Ying
Hi @nrezvanpour_arc ,
I believe you have tried the "Sort by" option in Chart setting. But just wondering why that does not meet your requirement.
EmilyBettler1
I am having the same issue, where I can only sort in ascending or descending (in my case alphabetical since it is a string field) order for my categories, but I would like to be able to manually sort them
