I'm configuring EXB app for my client. I notice that the query filter results seem a bit odd.
When we click on the action button, we will see loaded and all data count. Both seems always different.
I'm assuming loaded means data loaded into the app but no matter how I update the page size/index, the number never tally with all data. This gives some issue when the user selects "Show on map" action. It will not highlight everything on the map.
Anyone can enlighten me how exactly the query widget supposed to work?
By the way, I also found another weird behaviour. If we add the output of the spatial results as permanent table inside table widget, the table will only show record of intersect. Try to change the spatial filter to contains, within etc, the table does not refresh.
Would you be willing to work with our support team to create a reproducible app so we can investigate further? Thank you!
Are there any updates? When trying to export results of the query widget there are options for "loaded" and "all" data. I am not sure why the totals are not matching, plus when exporting to csv the "loaded" data exports all the data (114) and the "all" export is only a partial export. This will be very confusing for the end user and I am not seeing an option to turn off the "all" export options. Any help would be appreciated!
