Query widget case sensitivity issue: query statement result in table does not match feature display on map
937
12-06-2024 11:25 AM
PuenteAdmin
We are fairly certain we have identified a bug in the EXB query widget. For a field that contains specific word that is capitalized in some records and not in other records, a query will return all results (both capitalized and not capitalized) in the table, but the graphics representing the same result that gets drawn on the map only show records that exactly match the case of the input query string. In other words, the query statement result in the results table does not match feature display on map for the query result. This is happening on a hosted feature layer in ArcGIS Online. The attachment clearly shows this issue, which can be replicated with other hosted feature layers.
JesseCloutier
Esri Community Manager
Hi @PuenteAdmin, we appreciate you sharing a potential bug with the broader Esri Community; however, Esri does not actively track software defects posted here. The official channel for investigating and validating bugs is Esri Technical Support. All customers experiencing a potential software bug should leverage technical support to report and investigate the issue.
By reporting bugs through technical support, Esri can better track the scope and impact of the issue across all our customers and better prioritize it with our product teams. Our teams can also investigate the issue more thoroughly to see if there is a solution, workaround, or patch to get you back up and running as soon as possible.
As a reminder, Esri Community is primarily a self-service support platform where Esri users can ask or answer each other’s questions, share feature requests, and collaborate to solve problems with GIS.
*Note that this is a scripted message prompted when posts allude to a potential product bug.
Jesse Cloutier
Community Manager, Engagement & Content
