Print Widget not Showing Legend in Template Setting
362
09-26-2025 06:20 AM
Shwarna_USC
I noticed that the Print widget configuration in Experience Builder doesn’t include a Legend option under the common template settings. Because of this, maps printed from my EXB app don’t display the legend.
Has anyone else run into this issue or know why this might be happening? For context, my map only contains feature layers. I’ve also attached a screenshot of the configuration for reference.
Shwarna_USC
I was able to find out the problem why legend is not showing printed map. If your map layers have any kind of Symbology effect in the web map, its not printing the legend from the map using printing Widget.
I hope Esri will solve the problem.
Laura
by MVP Regular Contributor
