Print widget and "Date"
637
07-03-2024 11:25 AM
abureaux
MVP Frequent Contributor
I am working with someone on a print template. They swear the field labelled "Date" is a string in ArcPro.
I see this same field in the Print widget:
No matter what I enter here, it is always overridden by a dateTime stamp:
Am I missing something obvious here?
abureaux
Problem solved.
"Date" is a reserved word, and using it in a print template results in EB (not WAB) converting the string into a dateTime. Interesting behaviour all around. Changing the field to something else (Draft_Date in our case) resolved the issue.
This is one of those "I hate being right" cases.
abureaux
Problem solved.
