is it possible to default the Map Layers list to switch on automatically when your Experience Builder App opens?
This functionality exists in the WAB.
To add to what @jcarlson is saying. The widget controller is responsible for that. Say you are using the foldable theme and adding a widget to the widget controller in the apps header. You will see as outlined in this image you can set a widget to open at start.
Thank you both, much appreciated 🙂
You can also add the widget to something like a sidebar tab or its own floating window, which can be adjusted to show when the page loads, too. But the widget controller is probably the simplest.
I think it would have to be the Map Layers that sits out with the map as the former does not allow you to toggle Layers on and off. Of course maybe there is a way to do that?I would be happy providing you can toggle Layers it can sit anywhere.
Do you mean the map layers widget that's inside the map itself, or a separate layer list widget? For the former, I don't believe so. For the latter, it's certainly possible, but depends on where you put the widget.
