Opening attachments (images) in the Image Viewer Widget
7084
14
04-30-2020 10:57 AM
JordanRising
I'm trying to open image attachments in the Image widget with a dynamic source. Is it possible to set a dynamic image source to attachments? The Gallery widget opens the image attachments fine, but they are thumbnails in the main viewer, and open in a separate tab if you click on them.
Any help on how to open these directly in the Image viewer would be greatly appreciated. Also, if clicking on an image in the Gallery could trigger opening that image in Image widget would be sufficient as well.
Thanks!
PilleRossi
As i understood this option to show images as an attacment is only for thouse services which are hosted in online. When  you'll support the display of attachments on a feature service and to do it also in ArcGis Enterprise?
I can post this question also in ArcGIS Enterprise group, but it would be great to hear perspective view also from ExB team.
Greetings,
Pille
DavidMartinez
Hi Pille,
The next update of Experience Builder on Enterprise (i have tested with 10.8.1) will support this functionality.
David
AzinSharaf
Hi David, @DavidMartinez
I tested the Image widget in ArcGIS Enterprise 10.8.1 but it doesn't recognize the attachment. I am using a webmap in ExB which includes a feature layer with attachment. (The data source is in Enterprise Geodatabase.)
DavidMartinez
Hi @AzinSharaf ,
Well, that makes sense why you're not seeing it. The next release of Enterprise will have the functionality to include the attachment as a source. Currently, that functionality is in Online and Developer Edition.
Cheers,
David
AzinSharaf
Thank you, David. The image widget works fine in ExB Dev edition 1.2.
