Hello, i need a multiselect with a search functionality just like the one used in the Filter widget in Experience builder, i cannot find what i'm looking for in jimu-ui.
Can someone help ?
@WalaZargouni The AdvancedSelect component is what you are looking for.
@JanSarata You are referring to https://community.esri.com/t5/arcgis-experience-builder-questions/experience-builder-advanced-select-component/m-p/1401266#M11783, right? We will note that and see if we can implement it.
I think you are talking about FieldSelector.
https://developers.arcgis.com/experience-builder/storybook/?path=/docs/components-jimu-ui-advanced-data-source-selector-fieldselector--docs
Take a look in the advanced folder of the Storybook to see if you find what you want. There are several similar options.
It looks like the FieldSelector component yes, but with the FieldSelector it works only with a datasource and its fields. i need to load the items of the select with an api call
Hi @TonghuiMing, as far as I know, The AdvancedSelect is still missing the method onSearchInputChanged which is really important while using with API calls as @WalaZargouni mentioned. Are there any plans to implement this method? https://developers.arcgis.com/experience-builder/storybook/?path=/story/components-jimu-ui-index-advancedselect--dynamic-data
Yes apparently the AdvancedSelect is what i need, the dynamic data example code is not available in the storybook, i tried implementing it as the following
The onChange={function noRefCheck(){}} function does not do anything. You will need to write your own onChange function to handle the click event as needed.
