Modify the Zoom level/scale of a searched item
2824
5
09-06-2023 08:00 PM
Labels (2)
Ed_
by MVP Regular Contributor
So in Experience Builder, the user has the ability to turn on the search option/tool on the map (not talking about the search widget). This search tool is linked to a geocoder(s). Currently when you search for an address it zooms to a scale shown below in the screenshot.
Now my question is, is there a way to modify the zoom level when using this search in Experience Builder?
Current output:
Question | Analyze | Visualize
TonghuiMing
@Ed_
In the map search, this is controlled by API goTo property - https://developers.arcgis.com/javascript/latest/api-reference/esri-views-MapView.html#goTo
However, there seems to be no way for customization of this search (telling from the screenshot it is a locator search). I believe the only workaround is to customize it in dev edition to change the scale
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Search.html#goToOverride
Ed_
Good morning @TonghuiMing and happy Friday,
Thank you for your response and for providing a possible solution.
Yes, it's the search widget that becomes visible when you turn on the search option under tools.
So, does that mean if I have to override the default scale, I would have to create the entire web map in ArcGIS Maps SDK for JavaScript?
TonghuiMing
@Ed_ If you want to use the search tool, unfortunately yes. But another workaround is to use the OOTB Search widget. The message action Zoom to allows you to configure a custom zoom level.
Ed_
Good morning @TonghuiMing, nice, thank you for pointing that out, cheers 🙂
Ed_
It turns you can actually edit the Zoom level of the map search tool in Experience Builder which is actually tied to the extent set in Map Viewer. This can be done by changing the extent box size under item details page settings.
