Map select tool limited to 100 features?
8583
13
05-04-2021 01:29 PM
Len
After adding a map to an Experience Builder app in the online geoportal and enabling the 'select' tool for the map, when I view the published app I am only able to select a maximum of 100 features with the select tool. Is this a default setting and, if so, can I change it somewhere?
Len
rrahrs
Saw your video.  Did it allow 4000 or did it ultimately limit you to 2000 once you tried in in the web map?  It seems that no matter what value I put in, it limits me to 2000.
lzk222
2000 is the hardcoded limit. I put in 40000 as a random large number. There is no workaround for this that I'm aware of.
AngelaSchirck
This is because when the layer was published it was set to allow max of 2000 records.  When you share as web layer you can change this here:
DAVIDWADSWORTH_LVVWD
Agreed. Thanks for showing everyone.
