List Widget - show number of records
1658
07-26-2021 08:45 AM
ctalleygreenville
In the image below - there is a List Widget at the top (circled in red) and at the bottom of the image is a FeatureInfo widget.
I would like to somehow display the number of records that are in the List Widget which should match the number displayed in the Feature Info widget (ie. 15).
Am I missing something in the List Widget that will display this?  Is this possible?
Carmen
JonathanMcDougall
@ctalleygreenville
If you add a text box, connect it to the data, then add in a Count() it will show you the number of records. If you choose to either have Selected Records or if a Framework Action is "active" then you'll get the correct figure.
There's a post a wee bit further down the list where I give a wee bit of a fuller answer.
If you want screenshots, just say.
JonathanMcDougall
@ctalleygreenville
