Layers window disappearing if it has to expand outside the browser frame
1249
6
02-01-2024 07:38 AM
J_Dan
Hi all,
I've been building some apps with Experience Builder lately and it's working fine for the most part.
I'm facing somewhat of a bug though with the map widget layers tool: each time I develop groups of layers from the list, the height of the layers window increases accordingly to display every sublayer (which is normal so far), but if the window has to expand down a lot to the point of exceeding the browser frame, it just closes and reset instead of showing a scroll bar to be able to scroll down the list.
The same happens if the layers list is fine but the symbols list (on its own tab in the same tool) is too long to be fully displayed on the screen without scrolling: it closes suddenly and it's nearly impossible to open it again as long as the same layers are active.
This issue occurs with both Edge and Chrome, while it's working like a charm on Firefox.
Anybody else is experiencing this? Is it a known bug?
Thanks!
Tags (1)
J_Dan
Hi @TonghuiMing, thanks for your interest. It seems like the issue has been solved with the last AGOL update, at least I have not experienced such problem over the last few days even on the Edge browser. If it ever occurs again I'll let you know!
TonghuiMing
@J_Dan Do you have a reproducible sample for us to take a look at?
J_Dan
TonghuiMing
That's great news. Thanks
ACBOTNJ
I am finding this to be an issue again with the Nearby Experience template.  If you'd like to see what I'm experiencing, review the following app.  Find sales, use the export tools, look around and eventually the Layer List widget will go blank.  It is either intermittent or I cannot find after which sequence of accessing tools empties the layer list.  BUT, if you keep looking around, the layer list will eventually go blank for some reason, but I cannot determine why...can you?
 NEAR ME REAL PROPERTY SALES
TonghuiMing
Hi @ACBOTNJ, it seems like this application is an Instant App, not the Experience Builder. It might be helpful to post in their channel so the corresponding team can follow up.
ACBOTNJ
Ah yes, thank you for pointing this out.  I was trying to switch to Experience Builder with support recently.  I am hoping to add the functionality to allow the user to download found related records in batch and also periodically add to the related table in batch from within the app without having to republish the application.  Did not seem like this was available yet.  Many thanks for checking it out and replying.  I'll keep looking through the Instant App help and see if I can find a suitable answer to this one.  Or I will move this one to Experience Builder and see if I cannot make it better from there somehow.
