Issues with selection of list items following a search
1145
05-26-2022 08:48 AM
ANRGIS
I am experiencing inconsistencies when selecting a record from a link following a search. We have a Big Tree Experience site that lists the trees in a list on the left (List1) and then based on a selection there, the map panel in the middle (Map1) and list component on the right (List2) respond on the selected records. This functionality works well until a search term is searched in List1. Once there is a search term entered and the list of items shows the results of the search, the selection of records in the list becomes inconsistent. Sometimes clicking a record selects the record and the other components react accordingly. Other times upon record click the selection seems to stay for a short while and the other components start to respond, but then the selection does not stick and the experience behaves as if there is not a selected record.
The attached screen recording shows the behavior when there is not a search term and then the unexpected behavior when there is a search term. Any help is resolving this is appreciated!
Tags (3)
ShengdiZhang
Hi @ANRGIS ,
If you entered "Maple" instead of "maple" in the search input box in list 1 and can't reproduce this issue, I think it's for the same reason as this post. And we plan to fix this issue in the next release.
Shengdi
ANRGIS
If I search using the term "Maple" I get the expected behavior. Looks like it is that case sensitivity issue. Good to know the fix is coming, thank you!
ShengdiZhang
Hi, this bug should be fixed in today's update.
