Is there a way to highlight a selected feature from a query?
1671
11
02-21-2025 05:02 AM
SimonCrutchley
When you run a query it is possible to set the results to appear on the map and zoom to them. However, you may have run a query that pulls back tens or even hundreds of records and zooms to the full extent. If you zoom to a single one, by clicking somewhere in the resultant box, the map centres on the feature, but there is no differentiation of the feature. In WAB a highlight box used to appear around the selected feature so you could see it.
There doesn't seem to be any obvious way to do this in EB, unless I'm missing an advanced feature somewhere.
SimonCrutchley
Enterprise (Portal 11.3) and they are Feature layers. I was planning to try and replicate in AGOL next week, but this is for internal use, hence Portal.
It's nearly home time here in the UK, so I'll come back to this next week.
Thanks again for your help.
SimonCrutchley
Hi Jeffrey, I tried this in AGOL and it works, so it looks like this is a bug in Portal ☹️. Thanks for your help with solving the mystery.
