Is there a way to format labels in the widget controller?
545
06-20-2023 02:17 PM
Laura
by MVP Regular Contributor
I would like my users to see the name of each widget without needing to click and go though them all. Some of my labels do not fit. Is there a way to make the label a few lines long or any way to display the full label?
Shen_Zhang
Hi @Laura
Widget controller is a compact container to organize widgets - it is true that labels can only be displayed in limited spaces.To address this, there are two possible solutions:
  1. Increase the spacing between widget icons: By allowing more space between the icons, there will be room to display the labels without truncation.
  2. Enable tooltips for the widget icons: Tooltips provide a useful feature where users can hover over the widget icons to view the corresponding labels. This way, even if the labels can't be fully displayed within the container, users can still access them when needed.
Please let me know if you have any concerns or further questions regarding this issue. Thank you!
Shen Zhang
Laura
I did increase the space and there wasn't enough room. Would love to see work done on this - 2 lines for the name,  changing size, etc
EricMahaffey1
Tacking on to @Laura 's request.  I'd also like to have the ability to edit the text so we can rename the widget
JeffreyThompson2
Renaming widgets is currently supported.
https://community.esri.com/t5/experience-builder-tips-and-tricks/changing-the-icons-and-titles-of-wi...
GIS Developer
City of Arlington, Texas
