Is it possible to update the search result symbology and/or change the map highlight fill/outline in ?
1948
9
08-06-2024 01:25 PM
AdamGebhart
I am trying to change the search result symbology but don't see where it can be done in the interface, let alone in config.json.  At the least I would like to change the point symbology so it jumps out at the user.  Is there a way in the interface and I'm looking past it?  I'd also take changing the flash properties.  Robert Scheitlin provided steps on how to update the search symbology in WAB but I haven't been successful getting those same changes to work in EB.
Additionally, I'd like to make changes to the selection highlight to give it a thicker border/halo.  Can I do something in config.json for that?
Ke_Xu
by Esri Regular Contributor
Hi AdamGebhart,
About updating the search result symbology, please try to use Record created message action. Then symbology could be changed.
Ke
AdamGebhart
@Ke_Xu
Thanks for the tip.  I'm not seeing a target when I add the Records created trigger.  Do I need to set up another trigger or action elsewhere?  My search widget resides in a sidebar, along with a Feature Info widget that displays the feature's popup(s) that are either chosen in the Search or by clicking in the map.
Ke_Xu
Hi AdamGebhart,
Layer source and Locator source should be selected at the same time.
Ke
AdamGebhart
@Ke_Xu
From the New search source?  My searches are by layer source and I'm not seeing that coming up as an option for those. If I add a locator I see that come up.
I can go the locator route if needed but I prefer not to in this app because in the AGO map I have a popup configured for my address points that uses Intersects to retrieve values from a polygon feature class.  That can't be done with a locator, right?  I'm essentially trying to recreate some of the former WAB District Lookup widget functionality.
Ke_Xu
I am sorry. Message action "Add to map" just for Locator result. It doesn't take effect on the result of layer source we added.
AdamGebhart
@Ke_Xu
Do you know if it’s possible to create a custom popup for a locator (service) and/or have it use the Arcade Intersects function?  My current setup is to search my address points and use Intersects to pull values from a polygon feature class/service to complete the address point popup.  If I can't do that with a locator or geocode service there isn't any use in adding it to the search widget.  The layer source search works well for what I need, it's just the results symbology needs to be better for the end user.
QunSun
by Esri Contributor
ArcGIS JavaScript API doesn't support border for highlight options, see details here - https://developers.arcgis.com/javascript/latest/api-reference/esri-views-View.html#HighlightOptions
AdamGebhart
@QunSun
Thank you.  Is there anything that can be added or modified to the config to make the borders/halo more prominent?  I see there is 'shadowColor' but that appears to be only for a 3D SceneView.
AdamGebhart
@Ke_Xu , @QunSun
I am circling back to this issue.  I'm in Developer 1.19 and still can't get the search symbology to display in my app.
I have a Records Created action set up to show results.
But point feature searches don't show any symbols at all.  *Note the result is in the lower right corner of the image but there isn't any highlight, etc.  The Record selection changes > Map > Zoom to action works though.
And if I execute a polygon search I see the default cyan symbol and not what's in the custom symbols settings above.
Again, my searches need to be set up on layers and not locators.
On a side note, I can get some polygon features to flash via Record selection changes > Map > Flash but not all, and it doesn't work at all for points.
