Inserting dynamic data into HTML code
1038
12-10-2021 04:34 AM
GeorgeKhristoforoff
In my solution, I want to use the embed widget to demonstrate a certain html code depending on the selected data, but I can only connect to the data using url links. The use of personal links for each object is impossible, it is necessary to transfer attributes to the html code.
ABishop
MVP Alum
Hello George,
In your data, is there a particular field that could be used for a lookup item to the record in the URL?
Amanda Bishop, GISP
GeorgeKhristoforoff
No, i cant use URL. I need some attributes from arsgis layer for use in HTML code on ExB app.
