How to move Widget Controler from Body to Header
1734
08-03-2023 07:38 AM
JoseSanchez
Hello everyone,
I need t move a Widget Controler  from the Body section to the Herder section.
How can I do that?
Thanks
JeffreyThompson2
MVP Frequent Contributor
As far I can tell, it is impossible to simply move a widget between the header and body. You will need to make a new widget controller in the header, add all of the widgets you were using into the new controller, and configure the widgets as they were previously set.
GIS Developer
City of Arlington, Texas
ShengdiZhang
A simple way to move a widget is to select it in the body and press Ctrl+C, then go to the header and paste it by pressing Ctrl+V.
