How to Customize the Label for Related Records in Experience Builder Map Widget?
436
05-22-2025 10:33 AM
Labels (2)
PamelaFreitas
Hey guys,
I'm building an application using ArcGIS Experience Builder and I'm using the Map widget to display features that have related tables.
When I click on a resource, the related records appear correctly, but the label for each related record only shows a field called co_unit, which is not very useful for users. I would like to change the label so that it shows something more meaningful — for example, a date or a description field.
I've already configured the popups and display fields, but Experience Builder still seems to ignore these settings when showing related records.
Is there a way to customize or control which field is shown as the label for related records in the map widget?
Any advice or tips would be greatly appreciated - thanks!
Ke_Xu
by Esri Regular Contributor
Hi @PamelaFreitas,
Is it displayed as expected in the Map Viewer? Could you post some screenshots?
Not yet.
Ke
SaraMuller
It is not displaying as expected. Below is the screenshots showing how it currently appears, along with the label format we would like it to follow
—similar to how it was configured in the previous versions of the web app:
