Good afternoon,
Yes. In the Map Widget Settings Panel, expand the Options submenu with Dock The Pop-up selected set the Position to Custom and click the box you want to move it to.
Hi @SanchezNuñez,
In the Map widget settings, you can either have pop-ups appear at the default position or switch to Custom and choose one of 6 docking locations within the frame of the Map widget:
Please note that to configure this, you must enable the 'Dock the pop-up' setting, which will always dock the pop-up when opened. However, users can still undock the pop-up once opened.
Please see the following documentation for more information: https://doc.arcgis.com/en/experience-builder/latest/configure-widgets/map-widget.htm#:~:text=Position%E2%80%94You%20can,pop%2Dups%20appear.
Hope this helps!
