How do I change header colour of widgets in Experience Builder?
4890
6
10-27-2021 03:43 PM
TaupoDistrict_Council
I have been trying to customise the look of Experience Builder with our organisation colours.  I haven't found how to change the colour of the search glass or the header of the widgets (e.g. Layers).  The default blue really clashes with our colours.
How do I do this??
ShengdiZhang
Hi @TaupoDistrict_Council ,
You can go to the theme panel, choose the Organization Shared theme:
Or you can click the Customize button to custom the primary color of the Default theme:
Regards,
Shengdi
ShengdiZhang
Regards,
Shengdi
Thanks, just what I needed 🙂
Andrew_Wolff
Why is it though when you set the same hex color it still appears darker in the widget header.
Hi @ShengdiZhang
I've tried the same way in the latest version of Dashboards ... but the ability to change button colours doesn't seem to be there.  I posted to the community a few weeks back but it hasn't had any answers.  Any chance you know your way around Dashboards too (I was hoping it would be a pretty similar template).  https://community.esri.com/t5/arcgis-dashboards-questions/how-to-change-button-colours/m-p/1269301
SueStewart
So I discovered a workaround to this problem.
Set your primary color.
Click the advanced color settings and locate your primary (labeled as Primary - 500).
Hover over the shade above it (Primary - 400), and make note of the hex code.
Now change your primary color to this new color and it should match better:
RandyMcGregor_BMcD
There is a blur effect on the widget popups that I would like to change (remove). Is it possible to do this?
