I have an Experience Builder app that consumes a map with a feature layer representing an indoor mapping system, where different features exist on different floors.
I'm using a Filter widget to allow users to filter floors based on a field called "floor" (e.g., floor = 1, floor = 2). The Filter widget is configured for unique selection, meaning users can select only one floor at a time.
I would like to use URL parameters to share a specific feature and I would like to pre-set the Filter widget via the URL.
https://doc.arcgis.com/en/experience-builder/latest/build-apps/url-parameters.htm
I’ve tried using a URL format like this:
https://experience.arcgis.com/experience/[MyAppId]#[MyWidgetId]=filterItems:{encoded JSON filterItems}
Where:
However, I haven’t been able to get it to work. How can I achieve this?
I would also like to know if this is even possible.
Thanks in advance!
Solved! Go to Solution.
Hi @aricraimundo,
The data_filter will only filter my data source, while the Filter widget will remain unchanged.
Yes, the state of the Filter widget does not change.
I would like to define the filter expression used in the Filter widget using URL parameters.
Currently this new feature is not supported.
Ke
The Filter widget now supports URL parameters the same way as the Search or Map widget inside the app URL settings in the recent AGOL Oct release. Let us know if you encounter any issues. Thanks for your feedback!
Hi @aricraimundo,
From the doc, the format url is:
http://experience.arcgis.com/experience/<AppID>/?data_filter=<datasourceID>:sqlexpression
The following is an example URL with an encoded filter parameters (objectid=3):
https://experiencedev.arcgis.com/experience/098526e7e8df4815877174370ba531b7/?data_filter=dataSource_2-e920fece5eda481aaa64b1854b3aedae%3AOBJECTID%3D3
You could click on the feature to getthe datasourceID.
Ke
Hi @Ke_Xu
Ari
Hi @aricraimundo,
Ke
When do we expect this functionality to exist in Portal? Is it part of the recent 12.1 release?
@FrancisUWHuskies Yes, 12.1 will pick that up.
@TonghuiMing Do you mean the Floor Filter widget for ExB or the regular Filter widget?
@FrancisUWHuskies The Filter widget. I don't think the URL parameter applies to the Floor Filter, and the original post is about the Filter too, just with the field name called "floor".
