failed to load Exp app
865
10-14-2022 02:35 AM
henrilebon974
Hello,
I use experience builder developer edition 1.9.
I have a problem when I deploye my app. Sometime the app is loaded normally but the main part of the time the app failed to load. I have the console in attachment..
henrilebon974
My problem is created by an ESRI JS API import.
Please, somebody from ESRI could explain how import JS API in a sub component. Not directly in the widget.
How create an utils file that uses the JS API ?
Thanks.
henrilebon974
The problem had a problem because the JS API dependency was not in the manisfest.json of a widget.
"dependency": ["jimu-arcgis"]
The app worked in dev but not in deployment.
regards.
