Experience Builder using custom theme cannot load in S3 bucket
1272
09-29-2021 07:27 AM
Muhammad_AzhaziqBin_Mohd_Azlan
I'm using custom theme for my Experience Builder Developer Edition. Upon deployment to S3 bucket, the experience builder cannot load.
After investigation I found out that the way Experience Builder fetch the manifest.json and variables.json as follows, <url>/cdn/0/themes/<theme name>//manifest.json (apply for variables.json).
It generated from jimu-core loadThemVariables and loadThemeManifest function. The extra slash will result in file not found for S3 bucket. In nginx and IIS seems ok.
Since I don't have access to non production code of jimu-core, I'll just remove the extra slash from the jimu-core (index.js) inside client/dist and remove the extra trailing slash.
My page can load after the change and nothing breaks so far (yet).
Hope this help others that encountered this issue.
I think Experience Builder core team might need to fix this in upcoming release.
P/S: This is for ExB 1.6 and 1.5 only
New update - It may still happen in the latest version
msutcliffe_esriau
Found same issue in the latest 1.6 release of Experience Builder.
Thanks @Muhammad_AzhaziqBin_Mohd_Azlan for the work around.
