Experience Builder in ArcGIS Enterprise 11.5 Constant React JS Error
8495
15
07-24-2025 01:24 PM
DavidColey
MVP Frequent Contributor
Hello -
I am constantly getting the following error message in the ArcGIS Enterprise 11.5 Experience Builder IDE:
Minified React error #130; visit https://reactjs.org/docs/error-decoder.html?invariant=130&args[]=object&args[]= for the full message or use the non-minified dev environment for full errors and additional helpful warnings.
Each time I get the error, one component or another will not load.  Sometimes its the Draw Widget, other times its a List, still  other times its the Map Layer widget.
Point is, when it happens I can't update my apps.  I have asked my security team if we have something in place blocking content from reactjs.org, but so far I have not heard back.
David
Tags (1)
mwartman_grey
DavidColey
yes this definitely looks like this should resolve both the "Chunk" error and the (hopefully) the React.org resource access errors. Thanks for the post reply on this @mwartman_grey , I don't know why I don't get these patch notifications any more.  I'll apply tonight and we shall see.
TapanDhar1
Hi @DavidColey @JuanMarvinW
The issue has been addressed.
could you please apply this patch: https://support.esri.com/en-us/patches-updates/2025/portal-for-arcgis-11-5-web-applications-patch
Issues addressed with this patch
  • BUG-000177808 - Web applications installed with Portal for ArcGIS 11.5 may intermittently fail to fully load all content, and the browser console shows the "ERROR: ChunkLoadError: Loading chunk xxxx failed." error message.
  • BUG-000177260 - Updating the federated server URL incorrectly updates portal content URLs, resulting in inaccessible content and negatively affecting federation.
Thank you!
TimLohnes1
The patch worked perfectly. Thanks, @TapanDhar1
LefterisKoumis
Version 12.0 fixed these issues?
DavidColey
Yes both the ExB editor and the Instant app config page show no errors when modifying my apps, behavior feels more solid. Thank you esri.
@TapanDhar1 @mwartman_grey @JuanMarvinW
