Experience Builder Get Map Coordinates Tutorial
1238
04-24-2023 07:20 AM
JeffreyThompson2
MVP Frequent Contributor
I am following the creating a custom widget tutorial from this page https://developers.arcgis.com/experience-builder/guide/get-map-coordinates/ and it is not functioning correctly. I cannot find the option to select a map when I import the custom widget. I have followed the directions on the page, cleared my cache and even copied the sample code. What am I missing?
The config.json was located in the wrong file. So if the select map option is not appearing for you, I recommend checking your file structure.
GIS Developer
City of Arlington, Texas
