Experience Builder - building expressions
4922
10
12-16-2021 10:12 AM
HelenCooper
I'm trying to use a button to link to a URL and pass a value from a data source.  I'm struggling to find any documentation on how to do this, and my random guesses at how to build the expression are not fruitful!
Could anyone point me in the right direction?
Many thanks,
Helen
Tags (1)
jcarlson
MVP Esteemed Contributor
You have to put that first bit in quotes.
"https://mapitout.co.uk/" + {globalid}
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
HelenCooper
Thank you @jcarlson , that sorted it - really appreciated!
rachelm
I'm trying to build an expression that will include multiple field values based on selected map features.  So it would look something like: https://mylink/....objectids=186,171
So far what happens is my string only takes the last objectid of all the features selected. is this possible?
JJ_Reyes
@rachelm - did you ever figure out if this was possible?
RyanBohan
You can include multiple attributes with the plus sign.  The Expression below gets the lat/long from the attribute and links to google maps walking directions.
JackDrost
Can someone tell me what the language is for these expressions, so I can find some documentation for it?  It doesn't appear to be Arcade.
KevinDonahue3
Thanks for sharing this image, but I've got a dumb question in relation to it.  I'm trying to feed some dynamic URLs with experience builder parameters through a button and everything seems to be working, but I can't for the life of me figure out how to copy and paste text into the expression.
The only way I can get my expression built out is by hand typing the entire thing.  This wouldn't be so bad with something like your example, but I'm looking a having to type several layer id's for filters by hand and that's a recipe for errors.  I just really feel like I'm missing something and doing this the hardest possible way.
Thanks in advance for any help!
agrescavage
The expression editor text box has been buggy and broken for as long as I can remember. It's not just you.
HelenCooper
Hi @KevinDonahue3 ,
I just had a go and am able to paste into the URL text box (as long as the 'link to' box is set to 'URL'.   Is that where you're trying to paste?
