Exp Builder connect add widget with near me widget
361
03-06-2024 07:13 PM
Jarrah82
I am trying to determine what data are intersected by a shape file  which is added to the map using the "Add Data" widget.
When selecting "Set Location" in the "Add Data" widget option (image: Add Data action), it opens the "Near Me" widget. But then nothing happens (image: NearMe display). I enabled / disabled the input option "Inputs location labels" without success (image: NearMe input). The "Near Me" widget only show the distance and drawing input options (image: NearMe display).
What am I doing incorrectly? What tips have you to enable the two widgets to link?
Cheers
TimF
@Jarrah82 - this may sound silly, but have you tried repeating the action again? As in, when selecting 'Set Location' for the first time, nothing happens. Does selecting it again work?
In the past I've found this second instance gave it the kick it needed... but that was from the Search widget as opposed to Near Me.
Jarrah82
@TimF - I did and it didn't work. The input locations is not showing. There is run option.
