ExB: Widget Controller not fully visible on window resize
1848
03-02-2022 10:23 AM
RaenaDeMaris
Hi all, In Experience Builder, the widget controller is only partially visible on resizing of the window when viewing live. Is there a way to fix this? Is there a way to cluster it or clamp it to the Home and extent change built-in widgets above it?
Full screen view, followed by when the screen size changes:
rbd
ShengdiZhang
Hi @RaenaDeMaris ,
By default, widget controllers use % as the size unit, so if you resize the window, the width of the widget controller will become smaller.
One way is to change the width unit from % to px in the widget style settings.
Another way is to customize the layout of medium and small screen sizes.
Regards,
Shengdi
ShengdiZhang
Hi @RaenaDeMaris ,
Regards,
Shengdi
RaenaDeMaris
@ShengdiZhang Thank you so much for the solution as well as the explanation and options! Much appreciated!
rbd
