ExB Questions Regarding Pop Up Image and Attribute Box resizing
2152
12-30-2021 05:20 PM
GISREAL
Hello
Additional Newbie question:
I am attempting to add an image to the attribute box. Several research results state to either insert an URL .jpg  and/or the actual Hyperlink in the configure pop-ups. Nothing works for me. (See attachments). I've even attempted to use a Syntax, "+" tab in Map Viewer and pray it follows the layers. No luck
Looking forward to the answer.
Thank again
ShengdiZhang
Hi @GISREAL ,
If you want to show the image in the popups, you can add it in the Map Viewer. Select the layer and choose Configure pop-ups, then Add Media Content:
Then the image will be added in the pop-up:
Another way is to use an image widget and connect it to data to use dynamic content.
Shengdi
ShengdiZhang
Hi @GISREAL ,
Shengdi
GISREAL
Thanks for the second question. I think I need to tweak my attribute table for the URL .JPG's. I followed your attachments and it appears to want to lanch. (See attachments)
Awesome. Much Appreciated!!!
