ExB Fullscreen mode map appears in place of header
1138
06-06-2024 07:34 AM
MarjorieDillinghamGOAA
Hello Everyone,
Just realized on the iPad version of our ExB app that the Map Widget in Fullscreen mode appears in the header and behind the Body Sections.  It works fine in desktop mode.
Hope someone else has seen this issue and it is a quick fix.
abureaux
MVP Frequent Contributor
@MarjorieDillinghamGOAA, I moved this to the EB form for increased attention.
But for the map, do you by chance have percentages set for it's position? Click on the map, and go to the "Style" tab (see below). Anything that isn't similar to "100%" width/height and "0%" position will move with the page. Absolute units will work as well, but it depends on your use-case.
EDIT: That moves more than I was thinking... Have you checked your Experience's "mobile" and "tablet" versions? Use this switcher in EB (see below). Desktop mode doesn't work on mobile devices (due to screen size).
TonghuiMing
Hi @MarjorieDillinghamGOAA
I cannot reproduce your behavior, is it from an AGOL app?
However, there is an issue of map fullscreen, especially on iOS devices, that we are aware of and will resolve in the upcoming online release.
