Edit widget, no option to select "no Value" or NULL
1485
04-24-2024 05:50 AM
LeoDCG
There doesn't seem to be a way to select a null value or "No Value" from the edit widget when using a symbology template.  The map viewer has the option to edit a null value however.
Tags (1)
Laura
by MVP Regular Contributor
Have you configured it to allow for null values in map viewer smart forms? Tell the edit widget to use map configs
