EB Survey123 Widget - Automatically select submitted record on map
1128
12-28-2023 10:11 AM
Labels (2)
Tim_Shapiro
Using the Survey123 widget, embedded in an experience builder app, I would like to create an action that automatically selects, and zooms to the newly submitted record on the map.  Is there a good way to accomplish this?
The best solution I have come up with is to add a filter under the survey pane that can be applied to filter the points on the map to the newest point added (using a date created field), but from what I can tell, there is no way to have the filter widget automatically select the filtered record - I only see options for zoom and pan.
An alternative recommendations would be appreciated.  thank you,
