Dynamic Content in Text Widget not displaying time with date
3053
04-08-2022 01:00 PM
lrfinley
I'm using the text widget in experience builder to display a record's date and time but the time does not show up with the date, even though the time is present in the field. Why is this?
ShengdiZhang
Hi @lrfinley
I cannot reproduce your issue, the date format in my text widget is the same as the format of the map popup:
Can you check if the time is also not displayed in the map popup window? And do you have the "Show time" option enabled in the map viewer?
Regards,
Shengdi
ShengdiZhang
Hi @lrfinley
Regards,
Shengdi
lrfinley
So now I'm running into a very similar type of problem but not exactly the same. So I can get the time to show up but it always displays in regular time instead of military time. So for example, the fields are displaying 1:00 pm instead of 1300, how I have designated it in the pop-up configuration in the web map. If I look at the table in the web map it is right, but whenever I connect to that layer in that map in a text widget in Exp Builder its losing that formatting. Does that make sense?
lrfinley
Thank you for replying! I was working with a 'view' of the original layer and didn't realize it until after this post, their pop-ups were configured differently somehow. I did the same work flow you outlined above and it worked! Thanks again!
AaronKoelker
I'm running into a similar issue, but I'm using a hosted feature layer that's just a hosted table (no geometry) and I can't seem to get the text widget to show times. I have tried connecting to it directly through the widget, as well as connecting to the data through a web map that has the 'Show time' toggle enabled on the field for the layer.
Does it not work for hosted tables?
-Aaron
