Deploying custom widget to Portal
11104
18
04-30-2020 07:00 AM
MichaelWen
I apologize for creating the same thread under Discussions but I'm unable to delete it.
I attempted to use this workflow to add a custom ArcGIS Experience Builder widget to our ArcGIS Enterprise Portal
Add custom widgets—Portal for ArcGIS | Documentation for ArcGIS Enterprise
I got an error saying 'Invalid AppBuilder Extension. Verify that "Platform" is correctly defined'
Can custom widgets developed with ArcGIS Experience Builder Developer Edition be added to the Enterprise Portal using the same workflow as WAB widgets?
milesleeaus
Hi, this is the temporary solution, the difference is that when you turn on the experience builder app, it just shows the real app outside directly, you don't need to click on the url link to the foreign application. But there is still no solution lie webappbuilder, to hang the widget and let all applications on line use it freely. Esri said the solution will come late this year or early next year.
mileslee_esri
Hi Rachelm, hope you issue had been solved regarding how to deploy the widgets, any question you could contact me via my working email:  [email protected]
MichaelWen_Timmons
Is there an update on this? Can custom EB widgets be deployed now?
Jianxia
We just wanted to update you the status on this feature. Starting with ArcGIS Enterprise 11, you will be able to add Experience Builder custom widgets in ArcGIS Enterprise to extend the builder similar to what you do with Web AppBuilder custom widgets. ArcGIS Enterprise 11 is planned to be available in July. Thank you all for your input!
mileslee_esri
That's a really good news, we could say good bye to WAB after so many years ~~ (but we still thanks WAB for the previous sucessful projects)
SimonSchütte_ct
MVP Regular Contributor
BAdejumo
I have done everything in this article (https://doc.arcgis.com/en/experience-builder/11.0/configure-widgets/add-custom-widgets.htm) and still getting same result
Grant-S-Carroll
I have created a blog post which describes a workflow using Azure DevOps to publish to ArcGIS Enterprise and keep the widgets updated for anyone that may be interested.
https://www.spatial-innovation.co.nz/post/creating-and-distributing-esri-custom-widgets-part-3
Jianxia
@Grant-S-Carroll - thanks for sharing!
