Customizing icon colour for Widgets Within Widget Controller
4997
6
04-03-2024 05:18 AM
Labels (2)
Remya_Ravikumar
The client has a specific color requirement for widgets inside which are provided within the widget controller.
Widget SVG Icon:  Is there a possibility to change the color of individual widgets inside the widget controller.
This is what was obtained from experience builder as you can see all widgets have same color.
But I want the icons to be as below.
This was achieved using web app builder.
Thanks.
JeffreyThompson2
MVP Frequent Contributor
The background color of these icons is not independently changeable. The icon color itself can be changed. https://community.esri.com/t5/experience-builder-tips-and-tricks/changing-the-icons-and-titles-of-wi...
Another possible solution is to put each widget in its own Widget Controller.
GIS Developer
City of Arlington, Texas
PGebhardt_Stone_Env
@JeffreyThompson2 I am trying to make my widget controller buttons look the same as the map buttons (like home_button.PNG). In my map, when I hover over or click on a button, the icon changes color. I like how that looks, but when I try to change that for my widget controller buttons, I can't change the icon color with a hover or select, only the background or text (like map_layers.PNG). Am I missing something or is this functionality just not available?
JeffreyThompson2
The icon colors cannot be changed on hover/select.
GIS Developer
OsayabaOdaro
@PGebhardt_Stone_Env I think the answer to what you are saying has already been covered in this earlier link - Custom Widget Button & Widget Title Bar Colors in ... - Esri Community
The answer in the link is that there are 2 quick methods-
Method #1: Edit the theme.
Method #2: Edit the Widget Controller.
In the Widget Controller settings, go to Advanced and set the color as desired. You can choose different colors for default, selected and hover, so the button will react to user interaction.
JeffreyThompson2
@PGebhardt_Stone_Env Changing the icon color on hover/select is now supported. Turn on Advanced and then look under Icon Style and set different Icon Colors for the Default, Selected and Hover Tabs.
Setting a different background color for each button is still not supported.
GIS Developer
LakshmiRajeevKumar
Hi, were you able to get a solution to this other than changing the icon color, I am also facing the same issue
