Custom widget - Unable to download the zip file
361
01-14-2025 04:44 AM
Thomas_Puthusserry
I am trying to test a custom widget deployment in ArcGIS Enterprise 11.1
Node version: 16.20.2 and EB version 1.10
Created  a sample widget locally and published it. Functionality works as expected.
When trying to download the zip file, it is not working. The error I see in the server folder command prompt is:
  [Error: EPERM: operation not permitted, rmdir 'C:\Temp\Apps\EB10\server\temp\1\cdn\1\assets'] {
errno: -4048,
code: 'EPERM',
syscall: 'rmdir',
path: 'C:\\Temp\\Apps\\EB10\\server\\temp\\1\\cdn\\1\\assets'
Any idea what this is and how to solve it?
Thanks in advance
JeffreyThompson2
MVP Frequent Contributor
https://community.esri.com/t5/arcgis-experience-builder-questions/possible-solution-if-the-exb-downl...
There are a bunch of possible causes of this problem. (Feels like its been sorted out in more recent versions.) Take a look at this thread it has a number of possible solutions. Start by trying to run your Command Prompt in Admin mode. That's the simplest possible solution.
GIS Developer
City of Arlington, Texas
Thomas_Puthusserry
Thanks @JeffreyThompson2 for your response. It turned out that I need to do this in a different way as explained here: https://www.esri.com/arcgis-blog/products/arcgis-enterprise/developers/add-experience-builder-custom...
In this case I got the compiled version of the widgets from the dist-prod folder which is hosted in the webserver and could add the manifest.json directly in the enterprise portal.
