Configure experience builder to zoom to records related to a table. Is this possible?
923
11-22-2023 07:30 AM
MDB_GIS
I have an AGOL feature class that has a relationship class between a polygon layer and a table. The table contains case numbers that are associated to each polygon. I would like to configure experience builder to search for those case numbers, select the associated polygon, and then zoom to it.
Unfortunately, I can only get two-thirds of the way there. I have gotten the search configured to use the table as a source. I have an action configured to select the related polygon of the selected table entry that was selected via the search bar, but unfortunately, I can't get it to zoom to the selected polygon, despite having a map trigger set up to zoom to that layer. Here are the settings I have:
Search Widget settings
Framework settings for selected the related polygon
Map settings to zoom to selected polygon
Any ideas why this doesn't work? I have gotten it to work on feature classes that don't have a related table. Is it just not possible on a feature class with a related table?
gis_KIWI4
Hi Matthew,
I have experienced the same thing and as far I am aware there is no solution to this.
Hopefully someone from ESRI can tell me I am wrong 🙂
RossVolkwein1
Also struggling to figure this out. In my case, I don't even see a Zoom Map Action for my table, only Filter and Flash
KatieHansen_NIFCAdmin
Hi @AlixVezina ,
Is it possible to take a look at this capability? An action to zoom to a related record. I am attempting to do what others above are, but I have a related polygon, not a record in a table. I am able to select a related feature/record but not zoom to it.
Thank you
Ke_Xu
by Esri Contributor
Hi @MDB_GIS @KatieHansen_NIFCAdmin ,
Currently we don't support to use table as trigger/action data to zoom to map, but it is under consideration. I will keep you updated.
Ke
