Changing the colour of numbered bullets in the in a Text widget
617
07-03-2025 08:03 PM
DerekPhyn
Hi everyone, I have a text widget in my experience with a couple of sentences that I wanted to prefix with a numbered bullet. However, no matter what I try with the formatting settings these numbers insist on being a navy blue when I want them white. Is there any way to change the colour of these numbers or is this a bug?
Ke_Xu
by Esri Regular Contributor
Hi @DerekPhyn,
The color of the bullets or numbering can be changed to match the color of the Text widget box.
It means that we need to select the whole Text widget and change its color. The color of bullet will change with it.
Please let me know if you have any questions.
Ke
JasonBOCQUET
Hi, if you're on arcGol you can use Arcade to format your text in a better way.
In another way, can you just select the text and change it's colour in the setting panel of policy ?
Ke_Xu
Hi @DerekPhyn,
Ke
