Can Near Me Results Be Used to Dynamically Feed the Analysis Widget?
366
12-18-2024 09:20 PM
Labels (2)
kronezone
Hi everyone,
I’m working on an ArcGIS Experience Builder app within ArcGIS Online that -attempts to- integrate the Near Me and Analysis widgets. The goal is to use Near Me to identify intersecting features from multiple layers with a project area and buffer to generate a report using a custom print service (similar to the process described here: Recreating the Screening Widget Workflow).
This workflow works well for most of the layers in my webmap/app, but a subset requires additional processing—specifically grouping, summarizing, and pivoting the results before inclusion in the report. Recently I have been exploring the possibility of using a custom geoprocessing service in the Analysis widget to handle this, but I am unsure if the resulting outputs from the Near Me analysis can directly provide the input data required for a custom script in the Analysis widget (at this time). I saw a note about how support was added recently to use Near Me results as an input location via th..., but I haven't been able to get it to work so I'm not sure if it's something I'm doing wrong or if the widget interactions/functionality just isn't quite at that stage yet.
Does anyone have experience using Near Me to dynamically feed results into the Analysis widget, or have ideas about an alternative approach for processing intersected features in a similar way? I am certainly open to other ideas that might streamline this workflow. Any guidance or suggestions would be greatly appreciated.
Thank you, I greatly appreciate your help on this!
